Can't edit the Menu from DWcs4
Thread begun 2/22/2010 12:12 pm by james276087 | Last modified 2/24/2010 5:44 pm by Eric Mittman | 4525 views | 8 replies |
james276087
From Dwcs4 , can't edit the Menu.
So i deleted the old menu and made new Menu buttons but can't find the way open Menu writer menu....
thanks for reading and little help
When you select the menu on the page in design view you should be able to edit it with buttons in the property inspector. You should get edit menu, edit design, and edit content buttons in the property inspector. Click on which one you would like to alter. Choosing the edit menu button will only make changes to the preset, not the menu on the page. You must either edit the design or the contents to make changes in the current menu.
james276087
Yes i did that way with DWcs3, but now with Dwcs4 and show FW button.
It doesn't show EDIT button, what am i doing wroing here?
james276087
I found it......
From Preferences click on SCRIPTS....then shows it.
For any others that may be experiencing this did you have to enable Edit > preferences > invisible elements > scripts?
If so the other setting that works with this one is View > visual aids > invisible elements. Both of these must be checked for you to interact with invisible elements.
sandy170299
Eric, I have both of these checked/enabled, and I still can't see my edit buttons.
If the menu code on the page has been altered you may not be able to edit the menu. If you do not think this is the issue you are experiencing and you have ensured that you have the invisible elements > scripts enabled along with visual aids > invisible elements then please post back with the page that has the menu on it along with a copy of the CSSMenuWriter folder from your site in a zip archive.
sandy170299
Eric, sorry to waste your time - I rebooted and it's fine now :)
Thanks for posting back about this, someone else experiencing the same thing might benefit from this info. No need to apologize, I"m glad that it is working out for you.
