I can't get my checkFieldGroup_One Column Check box to show up in my email
Thread begun 2/22/2010 9:26 am by ciliberto378710 | Last modified 2/22/2010 12:08 pm by Ray Borduin | 4458 views | 7 replies |
ciliberto378710
I can't get my checkFieldGroup_One Column Check box to show up in my email. All I get is Registration group Areas of Interest: Array". I know I can use the implode directive, but I don't where or how to place it. Please help.
replace:
<?php echo(str_replace("\n","<BR />",$pval)); ?>
with:
<?php echo(str_replace("\n","<BR />",(is_array($pval)?implode(", ",$pval),$pval))); ?>
ciliberto378710
Where to enter the code?
Thanks for the code, but where do I cut and paste that? Thanks.
In your email body... What do you have set as your email body?
ciliberto378710
email body
I'm not sure what you mean by that. I have this setup to send me an email with all of the form data when someone completes it. For the email body I used:
<?php foreach( $_POST as $pkey => $pval ) { ?>
<?php echo(str_replace("_"," ",$pkey).": ".($pval)); ?>
<?php } ?>
I understand that you want me to replace with the new code you sent me. Can I replace this WAUE_contact_1.php style sheet or do I need to re-input the code via Insert>WebAssist>UniversalEmail and then run through the wizard again?
If I run through the wizard again, does that delete the input data I have already completed and start over? If I also want to send an email to someone who fills out my registration form, but I don't want to send them the collected data, then I assume I complete the wizard again using only their email address and email body that I want to use. Is that correct?
Thanks for your help.
So replace the second line of your email body...
<?php echo(str_replace("_"," ",$pkey).": ".(str_replace("\n","<BR />",(is_array($pval)?implode(", ",$pval):$pval)))); ?>
<?php } ?>
ciliberto378710
I am now getting a parse error
I have figured out where to place the code in the email body, but when I test the form online I get a parse error as follows:
Parse error: syntax error, unexpected ',' in /home8/globalnr/public_html/test/WA_Universal_Email/WAUE_contact_1.php on line 45
What I am doing wrong?
You didnt' do anything wrong (except listen to me ;) )... I gave you bad code.. the last comma should have been a colon like:
<?php } ?>
(I also updated the original post to be correct)
