rounding tax, shipping and total
Thread begun 2/22/2010 3:50 am by tim.wolak331163 | Last modified 6/27/2011 9:58 am by Ray Borduin | 3523 views | 6 replies |
tim.wolak331163
For some reason after I updated a cart rule, now my cart is rounding the tax, shipping and total... is there a quick fix for this?
Thanks,
Tim
tim.wolak331163
need to resove rouding asap
I'm attaching a copy of my cart file, when I switched back to a copy the cart stopped rounding. I had to add to my free shipping discount rule so that it would only work for TotalWeight less than 30lbs. I'm not sure if this is causing the issue but I need to resolve this asap so it stops rounding and I don't get killed with free shipping on 60lbs of food :)
Tim
I'm thinking that the number of decimals setting on the first page of the cart is somehow getting updated along with the rules causing the problem. The shipping charge itself shouldn't ever introduce a rounding problem itself. The only rounding settings are on the first page of that interface. Make sure that is set correctly and it should resolve the problem regardless of shipping charges.
tim.wolak331163
Yes for the currency its set to 2 decimal places. Would you suggest setting it to another number apply the change and then change it back to 2 and apply the change again?
So even when working with the broken one it says 2? Maybe try updating it and then updating again... worth a shot I guess.
I'll open a support incident to look into this with you further. Update the incident with a phone number and a good time to contact you. Make sure you are ready to reproduce the problem when we call, since we will need to see it to fix it.
You can update your incident after logging in to the main webassist site.
henk303241
Hi there, I have the problem here. There are no decimals displayed.
Please attach a copy of the shopping cart file you are using and the page where you are using it. I'll take a look and see if I can spot the issue.
