"add to cart" function not working.
Thread begun 2/21/2010 11:44 pm by rikaG_510 | Last modified 2/23/2010 4:42 pm by Eric Mittman | 2948 views | 4 replies |
rikaG_510
I am using DW CS4 (build 4117), MAMP for localhost server connection.
The site design is done manually using MySQL/PHP (didn't use any WA plug in). So far made catalogue page and now I'm ready to add cart function.
I installed eCart 5 after uninstalling eCart 4.
I'd like to add "add to cart" button to my catalogue page, so I defined eCart object.
My problem is;
- there is nothing on "eCart Insert panel". The panel itself do exist, but there's no button for any function; so no access to "add to cart" function from this panel.
- So I tried "Insert > WebAssist > eCart > Add to Cart Button" but absolutely nothing happens by clicking this either.
The only way I can get this function is go to "Server Behaviors > eCart > Add to Cart".
But the wizard window looks a bit different from the one with "button tab". So I really want to try this with the wizard with button tab.
I wonder if I am doing anything funky... (I did follow "the common problem" solution - no change).
What could be happening to my DW and eCart 5?
Any advice?
Thank you in advance.
Rika
There may be a problem with your eCart 5 install. You should rename your configuration folder, then remove and reinstall your extensions. Here is a link to the steps to take for this:
showpost.php?p=12293&postcount=2
rikaG_510
Thanks Eric,
I did what suggested thread said.
I changed the folder name as it was told, and delete all the extensions for DW once.
Then I restarted the machine and DW.
But when I start up DW again, the folder "configuration" is somehow created again automatically. The result; still hasn't changed. Nothing on the panel... not sure if this is because of "configuration" folder though.
Is there anything else I can do to fix the problem?
Or should I just re-install the DW?
rikaG_510
Sorry, please ignore what I mentioned above, the point of changing the file name was for a new Configuration folder to be recreated... Ok I see that now.
But still no change is occurring.
I downloaded WAeCart500.mxp again and installed it, but no change.
Is there anything else I can do?
I have opened a ticket for you on this issue so that it can be looked into further. To check the status of the ticket or update it login and visit your support history.
supporthistory.php?
