Code shows through
Thread begun 2/20/2010 7:35 pm by jhmblvd | Last modified 2/22/2010 11:20 am by Eric Mittman | 2393 views | 3 replies |
jhmblvd
Code shows through
When I create the form with Form builder, the php code shows through in the text boxes.
Did you create a .php page and view it through a web server? Is there a URL where I can view the form you are having trouble with?
jhmblvd
Hi, I did it over again, and now it seems to be working except the CAPTCHA isn't showing. This form has both a captcha and a security question. I would like just the security question but when I try to remove the code it won't post.
So a few questions, if you are redoing a web form, should you delete the folder in your site that's titled "CsssFormBuilder" before inserting a new one?
I also would like to post my forms to a tool called "Form Tools" To do this you must create a post action that is a url to where the Form Tools is installed on your server and add two hidden fields will this cause issues?
The form is at contactme.php
For the CAPTCHA you need to remove this feature from the form within the CSS Form Builder interface. You can edit the form contents and go into the security group to find the CAPTCHA, then remove it.
You do not need to delete the CSSFormBuilder folder when creating a new form or redoing one.
You can add in the extra form elements to make it work with your script and set the action to your page. However, you might loose the ability to have both client side and server side validations in place. To make it work like this correctly you would need to add in the server validations from your form page to the new page you want to post to.
Please post back with any questions that you have about any part of this.
