Moneris - Canadian Payment Processor
Thread begun 2/20/2010 6:58 am by codamedia | Last modified 2/22/2010 8:43 am by codamedia | 2861 views | 4 replies |
codamedia
By chance - does Web Assist, or anyone else here have a script to connect to Moneris. They are used quite a bit here in Canada for processing. I understand it would not be a part of the eCart Wizard, I don't mind a custom integration.
On another note. If someone needs a custom processor script - can/will WebAssist create one, and if so - what are the general costs.
Dave BuchholzBeta Tester
I have done a few custom integrations with eCart, looking at the moneris site they have a few different solutions which one are you interested in using ?
codamedia
My client has not gotten back to me with the details. They are currently a Moneris customer with eSelect, so I believe will will just be adding the eCommerce module.
I've done many processors myself in the past with the old Interakt Kart system. I was just curious if anyone had already done it for eCart and Moneris. I just started using eCart so I'm not as confident with customizing it, however - from what I can see it seems a lot easier than what I am used to. I guess I really should just dig in and figure it out :)
Out of curiosity, when you do a custom solution with Web Assist, do you recommend starting with an existing system (like Authorize.net or other) then modify that - or do you build it from scratch?
I would generally start from scratch using the examples given by the payment processor as it often easier than trying to modify an existing file.
codamedia
Thanks for the insight. I am going to give it a try once I get the final info from my client.
