testing server
Thread begun 2/20/2010 5:19 am by i.edwards384429 | Last modified 2/22/2010 11:09 am by i.edwards384429 | 2178 views | 2 replies |
i.edwards384429
testing server
Hi
I've installed on my testing server (wamp) because give a choice I prefer to develop localy and then transfer to the live server.
Ok I had a few issues so I did a work around and installed on my live web sever and then copied the mysql and web site down to my development system.
Yes I did change the connections file;-)
When I run Index.php I get the error
Warning: require_once(../Connections/PowerStoreConnection.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\mbsuk\CSSMenuWriter\cssmw_home\menu.php on line 23
however the file is there. A futher investigaton tells me that assuming that line 23 is the error line it's calling the connection file using the code
require_once($WA_dotDotSlash . "Connections/PowerStoreConnection.php");
which I'm assuming is adding the ../ making the path from the root?
If I remove the line
<?php require_once("CSSMenuWriter/cssmw_home/menu.php"); ?>
from the index.php file is loads but no graphics are shown.
I uploaded to my web server and it works perfectly so somewhere I have a path wrong
any ideas?
thanks
Ian
Dani Chankhour
Correct, PowerStore installer will determine the path, which is why we recommend that you run powerstore locally and on your live server as well. but if you want to change the setting, you will need to modify these three settings in your local server database wa_settings table:
Root URL, Local Root, and Remote Root.
i.edwards384429
update
Hi
thanks for that I now have it working,
Ian
