CSS Menu Writer
Thread begun 2/20/2010 12:44 am by dawn401382 | Last modified 2/22/2010 10:43 am by Dani Chankhour | 1527 views | 1 replies |
dawn401382
CSS Menu Writer
I am trying to personalise the menu to my own design but really struggling to find how to
• range my menu to the right on the page
• centre my type vertically (top to bottom) in the menu bar
• get rid of some .gif arrows
• The text in my submenus range right instead of left - in the preview in CSS menu writer they are correct - but when previewed in a web browser from Dreamweaver they range right.
Help!
Dani Chankhour
- could you explain what you mean by this one? If you have a link as an example that would be great.
- to center your text vertically, you should use equal padding on the top and the bottom, this will give you the same effect.
- depending on which menu you are using if you click on the Design Tab, then click on the a tag under Link or Hover, you could see the background image and to remove you just need to clear the file name.
- to change the alignment, under the Type tab, change the Align drop down list to right instead of left.
