Strip unwanted fields from sent email
Thread begun 2/19/2010 11:39 pm by stevenc330599 | Last modified 2/25/2010 9:46 pm by stevenc330599 | 1470 views | 2 replies |
stevenc330599
Now my emails are arriving I wondered if there is an easy way to strip the following unwanted information from the email before it is sent:
Contact Security code: w2NhD
Contact nbsp: 38
SimpleContact submit x: 43
SimpleContact submit y: 30
I assumed that this is part of an array and tried using the 'array_slice' function on what I thought was the array holding the email contents, but the unwanted fields still made it through.
Thanks in advance.
If you open the Universal Email folder, you will see a Templates folder.. in there you will see where the body of the email is built.
It has a line that looks like:
if ($pval != "" && strpos($pkey,"Security_") !== 0 && $pkey != "x" && $pkey != "y") {
This should already remove any fields that begin with "Security_"... if you want to restrict more fields you can add them to this list, so it becomes something like:
if ($pval != "" && strpos($pkey,"Security_") !== 0 && $pkey != "x" && $pkey != "y" && strpos($pkey,"SimpleContact_submit") !== 0 && strpos($pkey,"Contact_Security") !== 0 && strpos($pkey,"Contact_nbsp") !== 0 ) {
stevenc330599
Thanks Ray,
That worked first time!
Steven.
