Problems inserting images on Server
Thread begun 2/19/2010 3:47 pm by sales356151 | Last modified 2/22/2010 10:34 am by Dani Chankhour | 1607 views | 1 replies |
sales356151
Im trying to insert the image on the live server.
Ive uploaded the image through HTMLEditor and works fine, uploads correctly and after the upload gives corect path to insert the image, so that works ok.
The problem is, if I go to insert an image and browse the server, then select the image it shows me the path of my localhost not the server, Ive gone through all the config files and looked in the editor settings but cant see where this needs to be changes.
Hope someone can help.
Jamie
Dani Chankhour
Under WebAssist->HTMLEditor->Site Settings and you should be able to make the updates there. If you want to do the change manually, you can browse to these locations:
HTMLEditor\editor\filemanager\connectors\php\config.php
and
HTMLEditor\editor\plugins\kfm\configuration.php
You can update the path in those files accordingly.
