Adding a $1 or $2 to the price via the SIZE Dropdown
Thread begun 2/19/2010 6:02 am by dave315749 | Last modified 4/05/2010 2:14 pm by Eric Mittman | 5098 views | 9 replies |
dave315749
How do I set up my product page so that when someone selects a xxl it adds $1.50 to the price when added to the cart.
Its all in a database and so the size field looks like
small, medium, large, x-large
Is there a easy way i can just put
small, medium, large, (+1.50 ) x-large
And then somehow ecart will know to add 1.50 ?
What is the best way to do this?
Do you have the values associated with the sizes in your db? If so you could create a new recordset to select the sizes from this table. This recordset will be used to populate a select list in your add to cart form for the size. For the value use the id of the size nad for the label use the size name.
Once this is in place you will want to add another size recordset that is just like the first one but it will be filtered on the posted value of the size select list, it will post the value that the user selected.
You can then use the bindings of this second size recordset in your add to cart server behavior to add the amount to your size amount column, and the name to your name amount column. You could also just add the price to the items price rather than having a separate column for the sizes price.
This is an overview and you will need to be able to craft the recordsets and setup the select list and add to cart server behavior. If you have any questions about this please post back with specific questions starting with the first steps. It is a good idea to work on this one part at a time rather than trying to understand and implement it all at once.
dave315749
Thats the only way of doing it? Because I Dont have a sepertate table set up for the sizes, because i would like keep it simple for the client,
Is there anyway to set it up as explained by my first post? so that the client could add certain amounts for certain shirts or sizes or special attributes?
That is just one way to do it if you have the size data in a separate table. You can do it much more simply directly in the code by checking on the size the user selected, then adding 1.50 to the price.
The code would need to go in your add to cart server behavior that is on the page and the specific code will depend on th name and value of your size select list, here is an example of what it might look like:
$ATC_itemPrice = floatval("2");// column binding for the price from the add to cart
if(isset($_POST['size']) && $_POST['size'] == 'xxl') $ATC_itemPrice += floatval("1.50");
If you post back with your add to cart page that has the size select list on it I could show you a more specific example.
dave315749
Code
Sometimes they put "XXL (30 - 34)" So can the code say when it "includes" the text "XXL" instead of = ?
here is the code to the add to card, it doesn't work this way.
// WA eCart AddToCart
if (isset($_POST["wearyourin_1_ATC"]) || isset($_POST["wearyourin_1_ATC_x"])) {
$ATC_itemID = $_POST["wearyourin_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "cart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_pdetail) && $totalRows_pdetail > 0) {
$row_pdetail = WAEC_findRecordMySQL($pdetail, "id", $ATC_itemID);
if ($row_pdetail) {
$ATC_itemName = "".$row_pdetail['title'] ."";// column binding
$ATC_itemDescription = "".$row_pdetail['shortd'] ."";// column binding
$ATC_itemWeight = floatval("".$row_pdetail['weight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["wearyourin_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_pdetail['retail_price'] ."");// column binding
if(isset($_POST['wearyourin_1_Size_Add']) && $_POST['wearyourin_1_Size_Add'] == 'XXL') $ATC_itemPrice += floatval("1.50");
$ATC_itemPicture = "".$row_pdetail['image_thumb'] ."";// column binding
$ATC_itemColor = "".$row_pdetail['colors'] ."";// column binding
$ATC_itemSize = "".$_POST["wearyourin_1_Size_Add"] ."";// column binding
$ATC_itemwholesaleprice = "".$row_pdetail['wholesale_price'] ."";// column binding
$ATC_itemstocknumber = "".$row_pdetail['stock_number'] ."";// column binding
mysql_data_seek($pdetail, 0);
$row_pdetail = mysql_fetch_assoc($pdetail);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$wearyourin->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemPicture, $ATC_itemColor, $ATC_itemSize, $ATC_itemwholesaleprice, $ATC_itemstocknumber);
if ($ATC_RedirectAfter != "" && $wearyourin->redirStr == "") {
$wearyourin->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
You could adjust the line that is adding the extra price to account for this like so:
if(isset($_POST['size']) && strpos($_POST['size'], 'xxl') !== false) $ATC_itemPrice += floatval("1.50");
I just added a strpos check for the xxl value within the posted element, if the xxl string is present in the posted value then it will add 1.50 to the price.
dave315749
Works perfectly
Works perfectly! Thank you very much!
Glad to hear that. Let us know if you have any other questions.
dave315749
Doesnt work when wholesaler is logged in.
You guys has helped me set up a wholesale log in , so when the wholesaler is logged in it gives them a different price and sets the trueprice of the item to the wholesale price.
When a wholesaler is logged in this calculation does not work to add 1 dollar for a xxl shirt.
What do you need to see to be able to fix this?
Please post back and describe a little about how the whole seller price is determined. Please also include a copy of your add to cart page and any alternate page that the whole seller would see. I can take a look to see if I can spot any problems.
