How To Link Image To Detail Page
Thread begun 2/18/2010 5:53 pm by online.order393818 | Last modified 12/12/2011 4:42 pm by bill3786 | 7332 views | 16 replies |
online.order393818
I need instructions on how to link the image on my item page to the detail page using eCart4.5.2 so that when the image is clicked it will load the detail page, and populate the detail page with all the information contained in that recordset?
Thank,
Jw
I assume the image is coming from a recordset and is displayed in a repeat region?
create a link around the image that will pass the item ID as query string variable using the ID column from the products recordset:
<a href="Products_Detail.php?ProductID=<?php echo($row_RecordsetName['IDColumn']); ?>"><image tag></a>
then on the products detail page, create a recordset that filters the IDCulumn on the ProductID querystring variable.
online.order393818
Thanks Jason,
That is correct the "image is coming from a recordset and is displayed in a repeat region."
When I click the add to cart button it load the detail page and the recordset information correctly. But when I click the image on the page it would only load a 'blank' detail page! Look at your example I can see that I didn't include the <image tag> in my code. Hopefully that will correct the problem.
online.order393818
This post has been deleted.
your links are pasing the ID, but there is no name to the variable:
/detail.php?=3
should be:
/detail.php?ProdID=3
On the detail page, you then need to modify the recordset to filter the ID column on the passed ProdID querystring variable.
online.order393818
Jason,
I understand what you're saying. But whats puzzling to me is that the "gear.php & music.php" that queries the same recordset doesn't have that problem, and they all are pulling information from the same recordset!
In the eCart Getting Started PDF it instruct you on how to link the image placeholder to a recordset, but it doesn't instruct you on how to link any of the pages, ie music.php, gear.php to the detail page. I'll re-examine my detail page code to try and isolate the problem there.
Thank you
look closely at the link on the gear.php page:
<a href="detail.php?ID=<?php echo $row_rsItems['ItemID']; ?>"><?php echo $row_rsItems['ItemName']; ?></a>
it is linking to the detail.php after.php, you can see a question mark followed by "ID" this is the name of the querystring variable being passed.
the value being passed is the ItemID from the recordset:
this creates the link as:
detail.php?ID=3
On the detail page, double click the recordset and inspect how it is created to filter the ItemID column on the ID querystring variable.
the issue on your page, is that you are not passing a name for the querystring variable
detail.php?=3
only a value.
If you are using the same details page from the eCaart sample files, you just need to modify your links to pass the value using the name ID:
detail.php?ID=3
online.order393818
Got it, and thanks again
Jw
online.order393818
Jason,
I've tried every possible combination adjusting the recordset filtering, and all of the combinations produce the same results...
The page flowers_Template.php is filtering correctly. It list all of the items in the recordset.
the detail.php is linked up from the flowers_Template.php page, but only to the first record in the recordset.
The add to cart button from the flowers_Template.php is working correctly by populating the cart page with the corresponding items when selected.
The attached file I have included the recordset configuration for both file.
Please take a look to see if you can identify my problem.
Thank you
Comment: Also I've notice that around the border of the images on the flower_Template.php page there it is red! And I've notice that this red border appears in DWCS4 after I enter the code to link up with the detail.php file! Just thought I'd share that with you in case you have some idea if that is a indication of something. I haven't notice that with other images that are just staticly linked!
the problem is the recordset filter settings, you are filtering the ItemCatID column:
Recordset Details:
Connection: connProd
Tables: Items
Columns: All
Filter: ItemCatID =
URL Parameter ID
Sort: ItemID Ascending
Set it to filter the ItemID column instead:
Recordset Details:
Tables: Items
Columns: All
Filter: ItemID =
URL Parameter ID
