recurring thumbnail renaming error
Thread begun 2/18/2010 3:44 pm by deafboyz_audio386924 | Last modified 2/19/2010 9:43 am by Jason Byrnes | 1843 views | 3 replies |
ok so I change the incorrect lines of code in the helperphp to the correct ones(the thumbnail renaming fix)
THen by some strange way they some back a couple weeks later.... it has happened twice. I notice it when my thumbnails arent named correctly all of a sudden....
I make sure i save the file and upload it to the server and testing server.
how could this be happening?
if you edit or apply a new Digital File pro server behavior, that file will be recreated.
You can set the permissions on the server for that file to read only to prevent it from being overwritten.
i set it to 555 which is read for all and execute for all b/c wont it still have to be executed.... is that ok?
thanks for the fix, that was startin to get annoying
that should work.
you can test it by trying to upload the helper php file, Dreamweaver should give an error.
