powerstore3 navigation won't refresh
Thread begun 2/18/2010 11:30 am by stuff223820 | Last modified 2/19/2010 4:23 pm by Eric Mittman | 2994 views | 3 replies |
stuff223820
installed PS3 in a test folder on live server. all worked fine. Moved all files to live directory on server, now any navigation is still looking for files in old test folder which has been deleted.. How do i correct this?
site is: shop.greengate.ca
Have you made any updates to resolve this issue? When I visit the site that is linked to I can navigate to all the areas I checked on without issue. If you are still experiencing the problem you might need to clear your cache in your browser before testing again.
stuff223820
it is still doing it. Mainly in the Admin side now... every link!
i changed this code in the menu.php file in the cssmenu folder for each of the "home" and "admin" files. seemed to help the public side, but not the admin side.. i have tried everything i know and no fix. It is definitely not a browser cache issue. tested on 3 computers.
$WA_localRoot = "";
$WA_remoteRoot = "";
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
TO:
$WA_localRoot = "/";
$WA_remoteRoot = "/";
is this tied into the testing install in the mySQL database at all? That is the last idea i have. keeps going to shop.greengate.ca/PW3TEST/Admin.......
the PW3TEST folder is what the test site was installed into and the all files move out of. that folder is also deleted.
I think you might be experiencing a problem with the setting that is stored in your db. Go into your db and look in the wa_settings table. In here look for the values of root url, local root and remote root. Update any that you see that are referencing your testing directory.
If this does not work for you I have opened a ticket. To update the ticket login and visit your support history page:
