Paths for image uploads
Thread begun 2/18/2010 5:28 am by JohnPicton | Last modified 2/18/2010 7:18 pm by Dani Chankhour | 2358 views | 3 replies |
JohnPicton
I've seen a couple of similar threads to this, but there doesn't appear to have been a solution as yet.
I've set the path for image uploads as /uploads in the HTML Editor global file upload settings. I've then uploaded an image. The image appears in the file manager on the server, and I can see a thumbnail of the image, but when I attempt to insert the image into the editor the path is incorrect.
The path used is /public_html/uploads rather than /uploads and I can't find where to change this. There's obviously a script somewhere that finds the root directory, but this means that it doesn't work properly.
I find that the reference to my image is entered as:
/public_html/uploads/files/logo.jpg
when it needs to be:
Can you advise how I would correct this?
Dani Chankhour
In the HTMLEditor folder, browse to editor/filemanager/connectors/php and open the config.php.
Could you please reply with line 26 and 27 and line 41.
JohnPicton
Thanks for your response, the lines are as follows:
26: $WA_EditorLocalRoot = '/My Local Domain/';
27: $WA_EditorRemoteRoot = '/public_html/';
41: $Config['UserFilesPath'] = 'uploads/';
Looks like it's something to do with line 27 then?
Dani Chankhour
Yes, try changing line 27 to:
$WA_EditorRemoteRoot = '/';
ideasbyjr63389
Upload Path for files
This post has been deleted.
