ecart 5- same bug - (bind wizard) Get cart from RS
Thread begun 2/18/2010 4:22 am by web_assist_mail157665 | Last modified 2/19/2010 6:42 pm by Dani Chankhour | 2569 views | 5 replies |
The javascript issues which caused the (button - add to cart wizard) bindings interface to require a number of clicks on each item to get them to work, appears to affect the binding wizard window on Get Cart from RecordSet
just to say this is not fixed by the Button 'Add to Cart' Binding Wizards javascript fix - supplied a few days ago - this has the same symptoms, but I can only assume this window is driven by different script?
Dani Chankhour
You are correct, it is a different script.
I have opened a support ticket so i can send you the fix.
thanks Dani
Dave BuchholzBeta Tester
Dani,
when can we expect to see a point update with all these fixes included ?
Dani Chankhour
I'm not sure about an exact time for the next dot release, but will be creating a known issue early next week if the dot release is not being release soon.
