Powerstore3 Checkout problem
Thread begun 2/18/2010 4:22 am by info399484 | Last modified 2/23/2010 4:45 pm by Jason Byrnes | 3865 views | 6 replies |
info399484
Using powerstore 3 with no payment gateway configured.
On the page of " confirm.php" after I enter "submit order". I expect the shopping cart to be emptied and to now show the page "checkout_success.php".
However, The page "confirm.php" remains on the screen and the shopping cart is still full, making it too easy to re-enter "submit order" and to duplicate the order.
The orders are being processed and confirmation e-mails are being sent.
Please explain, how to change the behavior of the "submit_order button.
Thank you.
the Universal Email server behavior on the confirm page should be configured to redirect to the success page after the email is sent.
If the universal email server behavior is correctly configured to redirect, there may be a php error occurring, add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
If you need further assistance, please send a copy of the confirm.php page.
info399484
Hi Jason,
I need further assistance, I have attached a copy of Confirm.php
Many thanks
1) I don't see the code for turning on error reporting.
Did you try that? Was there an error?
2) Try changing line 1090 - 1092:
else if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))  {
  $WA_Store_Cart->redirStr = "checkout_success.php";
else if (isset($_POST["Submit_order"]))  {
info399484
Yes, I did try the code for turning on error reporting and it did not report any errors. so I removed it.
Further to your reply,
I have changed the code 1090 - 1092 as per your suggestion and the result is still the same.
The cart does not empty and it does not index on to checkout_success.php.
What next ?
info399484
Powerstore3 checkout problem
I have re-inserted the code for turning on error reporting.
and changed the code 1090 - 1092 "attached file confirm.php"
I am hoping for a response.
Thank you
try changing 1229 - 1231:
if (""!="")     {
    header("Location: ");
if (""!="checkout_success.php")     {
    header("Location: checkout_success.php");
