Pro maps not working for me
Thread begun 2/17/2010 4:05 pm by linda382561 | Last modified 2/18/2010 7:15 pm by Eric Mittman | 2479 views | 3 replies |
linda382561
It cannot find the address or coordinates I entered, and I get the following error message:
"While executing onMouseUp in wagmp_.htm the following JavaScript error(s) occurred:
At line 450 of file "C:\Program Files\Adobe\Adobe Dreamweaver\CS4 \Configuration\Commands\wagmp_map.js": wa.markerStyles[style] has no properties.
You may be experiencing a problem with the cache, here are some steps you can take to overcome this if it is the problem:
As for the coordinates not working please post back with some of the values you are using. Let us know if the js error is resolved also.
linda382561
Hi Eric,
Thanks for responding! I've deleted the file suggested by the PDF. I'm still having trouble with Google finding the location I enter. Oddly, if I enter it on the Google site itself, the location is found without a hitch. The address I'm trying to create a map for is:
262 Dog Trap Road,
Yass,
NSW 2582,
Australia
The version of the API that is used on maps.google.com differs from the one used in the Pro Maps for Google. It is often best to get coordinate values for these locations and use the coordinates instead.
A good way to get the coordinate values for these locations is to go to the location on maps.google.com and put the following code in your url then go to it:
javascript:void(prompt('lat,%20lng',%20gApplication.getMap().getCenter()));
It will return the exact lat and long for what is centered on the map.
