Cant delete, change, or fix UE
Thread begun 2/17/2010 6:13 am by tren297782 | Last modified 2/17/2010 11:31 am by Eric Mittman | 1763 views | 1 replies |
tren297782
So I got a javascript error on one of my pages that contains a UE form. I went to go and delete the UE from the server behaviors tab and when I clicked the delete I got this error :
While executing deleteServerBehavior in WA Universal Email.htm, a JavaScript error occurred.
I can not delete or change any of the settings,
What gives?
The page that contains the scrip is at
brochure.asp
Thanks,
Tren
You should try deleting your cache file to see if that resolves this problem for you, here are the instructions for this:
If this does not work for you then you may need to rename your configuration folder and re-install the extension. Here is a link to the steps for this:
showpost.php?p=12293&postcount=2
