Couponing and Discount System with database
Thread begun 2/16/2010 11:37 pm by victor278184 | Last modified 2/18/2010 2:35 am by CraigR | 3614 views | 5 replies |
victor278184
Is it possible to create Couponing and Discount System with database instead through dreamweaver interface (eCart Toolbar) ?
CraigRBeta Tester
it's certainly possible, and not too taxing, but you will need to do a bit of hand coding.
take a look at this thread from the archive...
forumdetail.php?MessageID=%3C7f014396%245c7818fa%249f4a6%40www.webassist.com%3A8119%3E
web_assist_mail157665
Please put dynamic discounts, cutoff dates etc etc up for a product suggestion
CraigRBeta Tester
database fields
here is an image of a database table which i used to do this...
victor278184
Hello CraigR, thanks for confirm a possible solution. I already thing that kind of solution, i even already "built" the eCart Interface so my client would able define almost everything we can set in the toolbar (decimal separator, the currency, etc).
it's not finish yet as i'm in process to write one by one of every possible code that eCart write in the .php cart specification... but i'm using eCart 4.. kind a wish eCart 5 would able to do the job for me (especially the discount feature) to save my time (it's a worth reason for an upgrade).
how long you build the 'extra' code for eCart ?
CraigRBeta Tester
i did this a year ago with ecart 4 and it took about a day of coding, (mainly because a lot of it was trial and error
