Can I remove the cache?
Thread begun 2/16/2010 4:37 pm by eric378598 | Last modified 2/18/2010 10:02 am by Eric Mittman | 3181 views | 4 replies |
eric378598
I only use LAT and LON for all my members.
I have modified the code as best I could so far to get the result i wanted.
I do not need the cache page stuff (I believe) if every point has the lat / lon stored in the database.
What code can i remove if i never look up a zip, city....
Link: <a href="http://www.gtha.com/dsp_MemLnks.cfm">GTHA Members</a>
Code can be sent if needed.
My page shows 177 points and loads in 45 seconds to 3 minutes depending on environment.
This is too slow for me. I am used to very quick respones from my database.
From the posts, it seems this page cache stuff is causing the issue. I don't need to lookup addresses.
Any help the great minds of this forum can provide is greatly appreciated.
Kindest Regards
Eric
eric378598
Took out the code
I went ahead and took out the code that gets the LAT LONG by address in the wagmp.cfm file I use.
Did not see any difference in load speed.
I will now look into loading the map first then the points.
My wagmp.cfm file is now this....
<cfquery name="qry_members" datasource="#application.dsn#" username="#application.dsnuser#" password="#application.password#">
SELECT [mem_id]
,[member_name]
,[street_address]
,[city]
,[postal_code]
,[phone_number]
,[website]
,[tblmemLatLon].[Lat]
,[tblmemLatLon].[Lon]
FROM [memberstbl] LEFT JOIN [tblmemLatLon]
ON [memberstbl].[mem_id] = [tblmemLatLon].[PK_ID]
WHERE memberstbl.delete_status <> 1
AND memberstbl.mem_id <> 171
ORDER BY memberstbl.member_name
</cfquery>
function WAMapRef(mapObj) {
this.obj = mapObj;
this.directions = false;
this.icons = [];
this.markers = [];
this.addresses = [];
this.points = [];
return this;
function WAMapPoint(theMarker, theAddress, theIcon) {
this.icon = theIcon;
this.marker = theMarker;
this.address = theAddress;
return this;
function wagmp_map_5() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_5')) return false;
var map = new GMap2(document.getElementById('wagmp_map_5'));
wagmp_map_5_obj = new WAMapRef(map);
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GLargeMapControl());
map.addControl(new GScaleControl());
map.addControl(new GMapTypeControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '<cfoutput></cfoutput>',
city: '<cfoutput></cfoutput>',
state: '<cfoutput></cfoutput>',
zip: '<cfoutput></cfoutput>',
country: '<cfoutput></cfoutput>',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'plugins/google_javascript/images/traditionalpillow_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalpillow_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'plugins/google_javascript/images/traditionalpillow_pacifica.gif';
icon_0.mozPrintImage = 'plugins/google_javascript/images/traditionalpillow_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalpillow_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalpillow_pacifica_transparent.png';
var icon_1 = new GIcon;
icon_1.image = 'plugins/google_javascript/images/traditionalpillow_pacifica_gtha.png';
icon_1.shadow = 'google_javascript/images/traditionalpillow_shadow.png';
icon_1.iconSize = new GSize(34,35);
icon_1.shadowSize = new GSize(34,35);
icon_1.iconAnchor = new GPoint(9,33);
icon_1.infoWindowAnchor = new GPoint(19,0);
icon_1.printImage = 'plugins/google_javascript/images/traditionalpillow_pacifica_gtha.gif';
icon_1.mozPrintImage = 'plugins/google_javascript/images/traditionalpillow_pacifica_mozprint.png';
icon_1.printShadow = 'google_javascript/images/traditionalpillow_shadow.gif';
icon_1.transparent = 'google_javascript/images/traditionalpillow_pacifica_transparent.png';
<cfset qry_members_id=0>
<cfoutput query="qry_members">
var address_0_#qry_members_id# = {
street: '[Address]',
city: '',
state: '',
zip: '',
country: '',
infowindow: '<cfoutput><a href="http://#qry_members.website#">#qry_members.member_name#</a></cfoutput>',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;">#Replace("<strong>" & ToString(qry_members.member_name) & "</strong><br />" & ToString(qry_members.street_address) & "<br />" & ToString(qry_members.city) & "<br />" & ToString(qry_members.postal_code) & "<br />" & ToString(qry_members.phone_number) & "", "'", "\'")#</span>',
full: '<cfoutput>#Replace("" & ToString(qry_members.Lat) & "", "'", "\'")#</cfoutput>,#Replace("" & ToString(qry_members.Lon) & "", "'", "\'")#',
isdefault: true,
addressType: 'coordinates',
loop: 'qry_members',
latitude: '#Replace("" & ToString(qry_members.Lat) & "", "'", "\'")#',
longitude: '#Replace("" & ToString(qry_members.Lon) & "", "'", "\'")#',
markerStyle: 'Google Traditional (pillow)',
markerColor: 'Pacifica'
if (address_0_#qry_members_id#.addressType == "coordinates") {
var cacheReturn = '';
if (cacheReturn != "" || (address_0_#qry_members_id#.addressType == "coordinates")) {
if(address_0_#qry_members_id#.addressType == "coordinates") {
var latitude = address_0_#qry_members_id#.latitude;
var longitude = address_0_#qry_members_id#.longitude;
var point = new GLatLng(latitude, longitude);
if (point && !isNaN(latitude)) {
wagmp_map_5_obj.addressFailed = false;
var marker_0_#qry_members_id# = new GMarker(point, icon_0);
GEvent.addListener(marker_0_#qry_members_id#, 'click', function() {
marker_0_#qry_members_id#.openInfoWindowHtml(address_0_#qry_members_id#.infowindowtext);
if(!fromAddress.enabled || 'address_0_#qry_members_id#' != 'address_0_0') {
if('address_0_#qry_members_id#' == 'address_0_0')
map.setCenter(new GLatLng(43.6573215, -79.3734778), 10);
map.addOverlay(marker_0_#qry_members_id#);
wagmp_map_5_obj.addressFailed = true;
<cfset qry_members_id=qry_members_id+1>
</cfoutput>
var gthalatlon = new GLatLng(43.639057,-79.380834);
var marker_gtha = new GMarker(gthalatlon, icon_1);
GEvent.addListener(marker_gtha, 'click', function() {
marker_gtha.openInfoWindowHtml('<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><br /><strong>Greater Toronto Hotel Association</strong><br />Phone: 416-351-1276<br />Fax: 416-351-7749</span>');
map.addOverlay(marker_gtha);
This is the smallest I have done yet!
I see other maps around that load faster, what is different with this method?
For those of you that use ColdFusion, yes, for some reason I needed to put my query at the top of this page even though the code generated did not.
Regards, eric
eric378598
a little faster
I REM'd out the geocoder control
It does seem a little faster.
The time to load locally on my PC is 10 seconds compared to 20 to 40 seconds live.
dsp_MemLnks.cfm is the live page.
eric378598
More code removed
SELECT [member_name]
,[street_address]
,[city]
,[postal_code]
,[phone_number]
</cfquery>
this.obj = mapObj;
this.icons = [];
this.markers = [];
this.points = [];
return this;
return this;
var fromAddress = {
enabled: false,
full: ''
street: '',
city: '',
state: '',
zip: '',
country: '',
infowindow: '',
isdefault: true,
</cfoutput>
That is my latest prune job. Took out more stuff I don't need. All in the name of speed!
I'm curious what specific changes you made that you found were most helpful for increasing the speed. This may be something that we can look into incorporating or changing up in the product.
