Parsing Errors
Thread begun 2/16/2010 1:37 pm by ruthc160065 | Last modified 2/16/2010 5:52 pm by Dani Chankhour | 2687 views | 1 replies |
ruthc160065
Parsing Errors
I am getting parsing errors when I try to use your CSS Form Builder. I am using Dreamweaver CS4. I added the simple contact, and simple appointment defaults, and it appears as if the form enters incomplete code.
The first error message I get is:
Parse error: syntax error, unexpected T_STRING in reservations.php on line 10
I look at the code and see its missing semicolans at the end of each validation statement on the following fields:
WAValidateDT((isset($_POST["Contact_me_group_Pickup_Day"])?$_POST["Contact_me_group_Pickup_Day"]:"") . "",true,"","","",false,"","","",true,1)
WAValidateRQ((isset($_POST["Contact_me_group_Name"])?$_POST["Contact_me_group_Name"]:"") . "",true,2)
WAValidateEM((isset($_POST["Contact_me_group_Email"])?$_POST["Contact_me_group_Email"]:"") . "",true,3)
WAValidatePN((isset($_POST["Contact_me_group_Mobile_Phone"])?$_POST["Contact_me_group_Mobile_Phone"]:"") . "",false,true,true,4)
So I add the semicolans and test again, and get the following error:
Parse error: syntax error, unexpected ')' in reservations.php on line 137
Basically this piece of code is incomplete as well:
if (ValidatedField('reservations','reservations')) {
if () {
if (!(false)) {
I am not really sure what to put in that code. please advise...
I have tried creating dozens of forms from the simples custom fields, to simply using the simplest ready made contact fields or appointment fields you offer, and no matter what, I get the same errors.
Its been a HUGE waste of time, money and learning curve trying to get the CSS Form builder to work for me in CS4.
I am hoping you can help point me in the right direction.
Because its taking me so much time to try to get past this issue, unless you can help, I will need to go back to doing forms the simple way, without the CSS Form Builder.
Thank you for your support,
Ruth
Dani Chankhour
Could you please send me your page in a zip file. I just need the page with the form on it. This will help me debug the issue.
I just did a quick test with a simple contact form and a single appointment form with no errors, did you do any modifications to the form or did you just use the quick insert to create those forms?
