menu writer
Thread begun 2/16/2010 11:50 am by forresjack373465 | Last modified 2/17/2010 1:05 am by forresjack373465 | 2735 views | 4 replies |
forresjack373465
menu writer
page menu created with menu writer with cs3 in xp do function correctly on windows 7 but option to modify does not show.Is menu writer compatable with windows 7 .
CraigRBeta Tester
can you give more details of your problem ?
CSSMW is certainly compatible with windows 7, i am using it with windows 7 and Dreamweaver CS4
forresjack373465
menu writer
I built a template with css sculptor and used css menu writer for my nav. I was using dreamweaver cs3 and windows xp. everything was working find and I was able to edit my nav find. I and a pc crash with xp so I bought my self windows 7 everything went on find and I loaded up my back up of my website as its still not finished to add more to the nav but menu witer with not let me edit the nav. I am new to webassist hope you can advise
I have also tried building the menu again then go back to modify it to an existing CSS menu layouts but does not give me that option
Dani Chankhour
In the Dreamweaver Preferences, click the invisible elements and make sure the scrips check box is checked.
forresjack373465
menu writer
Thanks that has solved my problem
