Multiple record update only updates last record
Thread begun 2/16/2010 10:59 am by a.leone400979 | Last modified 8/12/2013 8:13 am by Jason Byrnes | 4455 views | 7 replies |
a.leone400979
I just purchased the DataAsssist extension to Dreamweaver, specifically for the purpose of being able to update multiple records. I followed the instructions titled "da_update_multiple_records_sr.pdf," and believe I did everything as instructed. However, my page only updates the last record. I have attached the file as a zip file.
One other issue I noticed is that, for some reason, the Submit button, ends up in the repeat section so it gets renamed Submit_ . I am not sure what I should do when I set up the form to avoid this.
Any suggestions would be appreciated.
Dani Chankhour
try uploading your file again, remember to zip your page before uploading.
a.leone400979
Multiple records update - file
Sorry about that. File is attached (zipped).
Dani Chankhour
It looks like it is an issue with the submit button, you will need to remove the submit button outside the repeat region(before the </form> tag) and remove the counter from its name:
<input type="submit" name="Submit" id="Submit" value="Submit" />
a.leone400979
Mulitple record update - only last record
Thanks four your help. You took care of the problem I had with the Submit button. However, it is still only updating the last record. If I edit multiple records, only the last record in the list is getting updated. Do you have any suggestions to resolve this problem?
Dani Chankhour
I have opened a support ticket to further assist you:
soundshape
Databridge 1.1.4 Update Multiple records only updates the last record
I have read the documentation and the I have followed the instruction closely. I have duplicated the error with Databridge 1.1.3 and Databridge 1.1.4. Update Multiple Records only updates the last record. Update Multiple records only updates the last record.
Looks like the repeat selection behavior was applied outside of the repeat region behavior.
change line 241:
<?php } while ($row_rsImages = mysql_fetch_assoc($rsImages)); ?>
<?php $RepeatSelectionCounter_1++; ?>
