Problem uploading files through the cms
Thread begun 2/16/2010 7:09 am by rpereira311575 | Last modified 3/01/2010 1:47 pm by Eric Mittman | 3869 views | 6 replies |
rpereira311575
Hello I have installed power cms onto a website I created on a live server adding content and stuff is fine however when I try to upload a file through the cms I get the following error
failure to save tmp file "D:\Temp\php\phpC229.tmp" to location "D:\Hosting\5457446\html\files\//53.pdf"
please advise.
Thank you
RAHUL
shadow329043
Did you add pdf to the allowed uploadable extensions list?
See this post showthread.php?t=9008&highlight=file+types
rpereira311575
Yes I ahve already included pdf in the allowed extensions.
I'm curious if this is happening for you when you attempt to upload any file or just a pdf? If this happens whenever you try to upload any file there is probably a permissions issue in with the directory specified: D:\Hosting\5457446\html\files\.
Please let us know if you have been able to upload any other files. Also, based on the name of the file in the error message it seems there could be a problem with the file name. What is the specific name of the file you attempted to upload?
rpereira311575
Problem with uploading file
This is happening with any attempted file.
RAHUL
rpereira311575
Probblem with file upload
Changed the permissions on the directory to read and write then tried to upload a file called icon_t.jpg
and got this error
failure to save tmp file "D:\Temp\php\phpA90D.tmp" to location "D:\Hosting\5457446\html\files\//icon_t.jpg"
Thanks for the info, I have opened a ticket for you on this issue so that we can look into it further.
To update your ticket login to webassist.com and visit your support history.
