How to create the image filename as the ID?
Thread begun 2/15/2010 8:08 am by diego.zuppa399503 | Last modified 2/17/2010 10:07 am by Jason Byrnes | 2365 views | 5 replies |
diego.zuppa399503
Hi!
I write you from Italy, I hope you will understand me...
This is my problem:
I want that the uploaded file name (foto1) become the same of the ID record name (id_automobile).
I'm using DFP & Data Assist.
I send you the page code so you can see it.
Thank you for your help.
Diego
You can only do that if the file upload occurs after the record is inserted, you will have to manually move the upload coded o that it is after the insert record code.
Then in the upload file server behavior, click the lightning bolt next to file name and select the WADA_Insert_automobili session variable that is created by the insert record server behavior.
diego.zuppa399503
Thanks!
Now the file is loaded in the folder with the right name, but the page gives me the following error:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\Program Files\xampp\htdocs\new-junior-team\admin\automobili_Inserisci.php:81) in C:\Program Files\xampp\htdocs\new-junior-team\admin\automobili_Inserisci.php on line 99
and the db is not updated.
This is the code:
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $newjuniorteam;
$WA_table = "automobili";
$WA_sessionName = "WADA_Insert_automobili";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "id_automobile";
$WA_fieldNamesStr = "id_marca|id_stato|nome|descrizione|prezzo|foto1|foto2|foto3|attivo";
$WA_fieldValuesStr = "".((isset($_POST["id_marca"]))?$_POST["id_marca"]:"") ."" . "|" . "".((isset($_POST["id_stato"]))?$_POST["id_stato"]:"") ."" . "|" . "".((isset($_POST["nome"]))?$_POST["nome"]:"") ."" . "|" . "".((isset($_POST["descrizione"]))?$_POST["descrizione"]:"") ."" . "|" . "".((isset($_POST["prezzo"]))?$_POST["prezzo"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["foto2"]))?$_POST["foto2"]:"") ."" . "|" . "".((isset($_POST["foto3"]))?$_POST["foto3"]:"") ."" . "|" . "".((isset($_POST["attivo"]))?$_POST["attivo"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,0";
$WA_connectionDB = $database_newjuniorteam;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../upload/",
'FileName' => "".$_SESSION['WADA_Insert_automobili'] ."",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "foto1", "0", "", "false", $WA_UploadResult1_Params);
Thanks for the help!
Diego
see the following for information on the headers already sent error message:
148/
Please add the original php file to zip archive and end the zip archive in your response instead of pasting the code.
diego.zuppa399503
Here is the original php
Fixed "headers already sent" problem
There remains the problem that the column of the file upload (foto1) is not updated into db
Thanks again for the help
Diego
since you are using the value of the id_automobile column for the files name, there is no need to store the name in the data base. it is also not possible since the file is not uploaded until after the record is inserted.
