Sculptor stopped working
Thread begun 2/15/2010 6:14 am by paul352948 | Last modified 2/17/2010 3:11 pm by Eric Mittman | 3734 views | 5 replies |
paul352948
Expression Web - Sculptor has stopped working - un installed - reinstalled no joy
When reinstalled Sculptor is an option in the menu , the outline box shows then disapears then the option isnt available in the menu options
What to do please
What is the version of Sculptor and Expression that you are working with and what is the OS?
Also, when you reinstalled did you go through the control panel to uninstall it first?
paul352948
Expression Web1 (12.06211.1000)SP1 MSO (12.0.6425.1000)
Operating system XP
CSSSculptor104
Control Panel unistall - No
Regards
Paul
Try to uninstall this from the control panel > add remove programs. If you completely remove it through this uninstall it should clear it out for you and allow you to re-install it by double clicking on the installer. Please give this a try and let us know if it works for you, if not I can get a ticket opened for you on this.
paul352948
Hi , followed your instructions - same problem -
Can you raise ticket please
Regards
Paul
Sure thing, the ticket has been opened up for you. To check the status or update the ticket login and visit your support history.
