Parse error
Thread begun 2/14/2010 7:30 pm by JMcKay400963 | Last modified 2/17/2010 5:39 pm by Dani Chankhour | 2274 views | 3 replies |
JMcKay400963
Parse error
I am new to PHP and this PowerStore but I can find my way around. I have been able to upload the Powerstore files to a test server and have progressed to the administration set up of the store. However at the top of the screen there is a Parse Error which is limiting the funcationality of the admin. I cannot add products, users, etc. Any help is greatly appreciated.
Parse error: parse error in C:\wamp\www\oaksteadmed\ecart\WA_Globals\WA_Globals.php(58) : eval()'d code on line 1
Here is the WA_Globals.php code:
//need to run installation wizard
if(!file_exists('../Connections/installed.txt') && (!file_exists('Connections/installed.txt'))) {
if(file_exists('../install/index.php')) {
header('Location: ../install/index.php');
} else {
header('Location: install/index.php');
exit();
function replaceTokens($encodedVal,$Arr) {
$tokens = preg_match("/\\[([^\\]]*)\\]/",$encodedVal,$subMatch);
$retVal = $encodedVal;
if (sizeof($subMatch)>0) {
$ArrIndex = $subMatch[1];
$ArrPos = explode(":",$ArrIndex);
if (isset($Arr[$ArrPos[0]])) {
for ($x=0; $x<sizeof($Arr[$ArrPos[0]]); $x++) {
if ($Arr[$ArrPos[0]][$x][0] == $ArrPos[1]) {
$retVal = str_replace($subMatch[0],$Arr[$ArrPos[0]][$x][1],$retVal);
return $retVal;
$thisDir = realpath(dirname(__FILE__));
if(strpos($thisDir,"/") !== false) {
$thisDir = substr($thisDir,0,strrpos($thisDir,"/"));
} else {
$thisDir = substr($thisDir,0,strrpos($thisDir,"\\"));
require_once($thisDir."/Connections/PowerStoreConnection.php");
mysql_select_db($database_PowerStoreConnection, $PowerStoreConnection);
$query_WAGlobals = "SELECT * FROM wa_settings";
$WAGlobals = mysql_query($query_WAGlobals, $PowerStoreConnection);
$row_WAGlobals = mysql_fetch_assoc($WAGlobals);
$tabs = array();
while ($row_WAGlobals) {
if ($row_WAGlobals['grp'] != "None") {
if (!isset($tabs[$row_WAGlobals['grp']])) {
$tabs[$row_WAGlobals['grp']] = array();
$tabs[$row_WAGlobals['grp']][] = array($row_WAGlobals['name'],$row_WAGlobals['value'],$row_WAGlobals['type'],$row_WAGlobals['options'],$row_WAGlobals['variable']);
foreach ($tabs as $key => $value) {
for ($x=0; $x<sizeof($value); $x++) {
eval("\$WAGLOBAL_".$value[$x][4]."='".replaceTokens($value[$x][1],$tabs)."';");
//root url
$WAGLOBAL_Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] . $WAGLOBAL_localRoot;
mysql_free_result($WAGlobals);
Dani Chankhour
I'm assuming you have not changed this file.
But looking at where the error is generated, it might be that it is not finding the connection folder.
Are all the PowerStore files and folder under the ecart folder?
JMcKay400963
Yes, all files and folders are located in the ecart folder
Dani Chankhour
OK, Can you check if the database tables are created correctly? (specifically, look for a wa_settings table)
The line of code that is breaking, is trying to set global settings which is reading from the database.
