Level 1 Menu Level1 Item Truncated
Thread begun 2/14/2010 5:17 pm by clive.henderson222953 | Last modified 2/18/2010 1:16 am by clive.henderson222953 | 2867 views | 4 replies |
Hi
Can anyone help or point me in the right direction please?
1) My vertical menu seems to display OK but level 1 entries are truncated
An example is here
template.php
2) Is there a way of having an ampersand in a menu item name? I've tried & which it seems to accept but the html validation checker still throws it out as an error.
Clive
neilo
Hi Clive,
Select your leftSidebar div, and in the CSS Styles panel change the overflow from 'auto' to 'visible'.
Justin Nemeth
It also looks like removing the overflow property does the trick as well. Setting it to visible or removing the overflow seems to have the same effect.
That seems like the correct way to use a & to me. I suppose you could try & instead but that might give the same warnings.
-justin
Many thanks neilo
dis the trick wonderfully.
Much appreciated
Clive
Thanks for the response Justin
Guess what, I just tried & and it's worked now.
Strange!
Cheers
Clive
