Warning error on localhost
Thread begun 2/14/2010 12:32 pm by massimo173451 | Last modified 2/16/2010 11:04 am by Eric Mittman | 1407 views | 1 replies |
massimo173451
When I am working on localhost and run the PHP pages, receive the message showed in the image attached, where I can find the error and how is possible share both connections on localhost and server together? I can use only a single connection and comment the other one for avoid trouble. Follow the connection used by me on localhost or server.
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
#connessione su localhost
#$hostname_localhost = "localhost";
#$database_localhost = "PowerStore";
#$username_localhost = "root";
#$password_localhost = "ma06ssimo";
#connessione su server
$hostname_localhost = "xx.xxx.xxx.xxx";
$database_localhost = "xxxxxxxxxx";
$username_localhost = "xxxxxxxx";
$password_localhost = "xxxxxxx";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
Massimo
The error message you are getting is not referring to the details of the connection, just that the connection file cannot be found.
You should be able to resolve this problem by going into the CSSMenuWriter > cssmw_home > menu.php. In here you can update the include to have an extra ../ in front of it like this:
line 23
require_once($WA_dotDotSlash . "../Connections/PowerStoreConnection.php");
This path should be configured for you already though with the code. Do you get this on every page or only when you try to preview certain pages? Please let us know the details about this issue so that we can look into further if necessary.
massimo173451
This post has been deleted.
