Anyone done dynamic discounts?
Thread begun 2/14/2010 2:22 am by web_assist_mail157665 | Last modified 2/16/2010 11:04 am by web_assist_mail157665 | 3350 views | 2 replies |
Client requires updateable
discount percentage
discount cutoff date
on EACH product in a group (its an event sale)
I can LEFT JOIN the event and take a percentage and date from the event
this discount needs to be set up by the client
currently it seems everytime you want to have a discount you need to call the webdeveloper to change the cart?
I can easily get the products discount percentage and cutoffdate from a recordset (left join products and event with FK from product to event), when I get the rest of the product details for the cart
And I can create columns in the cart for Discount_Date (date) and Discount_Percentage (number) - then bind to each of the recordset values
And I can create a discount calculation
test - the values are going into the cart - OK
DiscountDate = 2010-12-31
DiscountPercentage = .1
BUT...
If I then do a discount
If Todays date is before (in box) DiscountDate (cart Column variable)
Cart Subtotal * (in box) DiscountPercentage (cart Column variable)
I DON'T get any discount
//eCart Rule
function WAEC_eCart1_Book_BeforeDate_Discount() {
$totalDiscount = 0;
if (true && ((time() <= strtotime("DiscountDate")))) {
$totalDiscount += ($this->TotalColumn("TotalPrice") * DiscountPercentage);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
manually replacing these with a date and a number causes the thing to work
any ideas?
AMEND:
As far as I can see (as a non programmer) Neither of the two variables are put into the formula
correctly
strtotime("DiscountDate") is just seeing the text "DiscountDate"
($this->TotalColumn("TotalPrice") * DiscountPercentage) doesnt see anything in DiscountPercentage
Amend by hand seems to work
would be interested in better 'ecart' way if there was one! (other than entering a manual expression - true etc)
//eCart Rule
function WAEC_eCart1_Book_Before_Date_Discount() {
$totalDiscount = 0;
if (true && ( time() <= strtotime($this->DisplayInfo("DiscountDate")) )) {
$totalDiscount += ($this->TotalColumn("TotalPrice") * ($this->DisplayInfo("DiscountPercentage")));//Result
//eCart Rule
You could do this from within the discounts interface, you would just need to add in the code that you updated the date to be like:
" . $this->DisplayInfo('DiscountDate') . "
If you use this in the interface it should appear in the charge rule the same as you have it now.
The problem with doing it this way is that you are not selecting the discount date for a given item but for the current item. If you had multiple products in the cart with different discount dates you would get some mixed results depending on what date appears first.
I think it might be better to store these values in session variables, then make use of the session variables inside of the discount rule. You can just put the code for the session value in for the date like this:
" . $_SESSION['<your DiscountDate session var>'] . "
This way you can control what is in the session variable and how the discount is applied.
thanks Eric
I'll try and get my head around this.
Re mixed dates
As this is an event - products are only on offer for that event (the same date)
but appreciate you mentioning it
Individual discount dates would definitely be the way to go if it were arranged any other way
