PHP File System Question
Thread begun 5/12/2009 5:46 am by Ian | Last modified 5/12/2009 11:15 am by Justin Nemeth | 3206 views | 2 replies |
Ian
I am in the process of migrating from ASP to PHP and I would like to know if someone can point me in the right direction with a query that I have.
I need to be able to parse a directory that contains images, and add the filenames to an XML file. Is this possible with PHP?
Cheers
Ian]
Yes. Look at php.net and you can read about the php xml parser that will allow you to read and manipulate xml in php: book.xml.php
Justin Nemeth
SimpleXML is another good and easy to use method for working with XML files - simplexml
