How to edit a recordset?
Thread begun 2/13/2010 8:45 am by nickj | Last modified 2/13/2010 10:55 am by nickj | 1379 views | 2 replies |
nickj
On my results page I want the recordset to join with a table of labels to add meaningful content but the recordset is not in the bindings panel and the the code is a little unclear as to what the recordset is being filtered by.
How do I edit the recordset built by the wizard?
thanks
Nick
nickj
If I knew where the "Where" viable was set then I could build a record set based on the same variable but it's far from clear!
How do I base a results page on a complex query which uses joins, groupings and unions?
nickj
never mind
I had re-installed without activation....
