Theme-It GMC 3 Beta Build Available for WCE
Thread begun 2/12/2010 1:48 pm by Justin Hood | Last modified 2/12/2010 1:48 pm by Justin Hood | 459 views | 0 replies |
Justin HoodWebAssist
We've added some cool new features! Check them out!
A zip file will be emailed to you today, containing Theme-It GMC 3 (Beta).The beta build is only available to the WCE group so please do not report bugs or feedback in the regular support forums; use this forum to provide us input or ask questions.
The serial number for this group is h0sEH-A5RsP-0x2nB-r2Ltr. There are a limited amount of activations so please do not install on more than 2 machines. This serial number will work until it goes live in early March. Post here, if for any reason, it doesn't work before then.
Please start a new thread when submitting feedback. Thank you.
Items addressed in GMC 3:
*'Tweak-It' feature added. A numeric value from 1 to 359 can be entered and all colors will be moved the corresponding number of degrees in the color wheel. This a quick and easy way to quickly change your color schema.
*A full color wheel has been added to the Manage Colors tab.
*Corrected an issue that caused incorrect color suggestion results when using 'Complimentary'.
*Corrected an issue that prevented Theme-It from locating CSS contained within PHP include files.
*Corrected an issue that prevented THeme-It from locating CSS when site root relativel inks were used.
*Updates made for Dreamweaver CS5 compatibility.
*Corrected an issue that prevented the current document from refreshing in Dreamweaver after using the Revert option.
*Corrected an issue that caused a required validation alert loop to occur when focus was set to the 'Base Color' field and no value was entered.
*Image references to an image that doesn't exist will now be listed in the Manage Images tab so that a new image file and path can be selected.
*Corrected an issue that caused changes to an image path to not take if the image was used in a class that was also having it's color modified in the same Theme-It session.
*Corrected an issue that prevented Theme-It from seeing changes made to CSS from within Dreamweaver unless the page was saved prior to running Theme-It.
