view cart button
Thread begun 2/12/2010 12:58 pm by jim286478 | Last modified 3/29/2010 6:14 pm by Eric Mittman | 2541 views | 4 replies |
jim286478
view cart button
I have eCart working fine for this store I am working on and all the pages seem to function properly except for the view cart button. I am placing the view cart button in a DW template because I want the view cart to be on every page but every time I place a view cart button on the php pages I get an php error saying call to an undefined function. And when I remove the button everything works fine again. Is there an issue with the view cart button or something else I need to do beside what is says in the help files?
jim286478
OK, I found out a bit more! What I stateda bove is true when I insert the view cart button on the DW template so it could show up on all pages and it creates an error. However, when I insert the view cart button in a non-template page, it works fine so I gather there must be a link problem but I don't know!
The code for the view cart button relies on the including of the WA_eCart/<your cart name>_PHP.php file. That include line of code would normally look like this:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
If you have the template in a template directory you might need to add ../ to the front of this path like this:
//WA eCart Include
require_once("../WA_eCart/eCart1_PHP.php");
jim286478
Thanks for your help.
Your welcome, let us know if you have any other questions.
