Display above FLV
Thread begun 2/12/2010 8:52 am by rob293221 | Last modified 2/12/2010 2:59 pm by Jason Byrnes | 2966 views | 5 replies |
rob293221
Display above FLV
I can not get the menu to display above the Flash Video files on my site. The menu displays behind the video. Does anyone know how to correct this?? Files attached. Thanks!
neilo
It's difficult to test with what you've provided, but you could try adding a z-index value to your 'ul#cssmw ul.level-1 > li > a { ' css rule in your CSSMenuWriter/cssmw/menu.css:
background-color: #999999;
background-image: none;
some more styles here;
padding: 6px 10px 6px 5px;
width: 150px;
z-index:999;
That might do it.
rob293221
That did not do the trick. What items do you need me to post to make it easier to look into this? Please help with any other ideas. Thanks!
please post a link so we can see the problem in a browser.
rob293221
TYL017_scene1.php
user: support
pass: webassist
When the menus appear behind a Flash element on the page it is likely do to the wmode setting of the Flash on the page. Here is a kb article from Adobe that discuses this and how to resolve it.
viewContent.do?externalId=tn_15523
Along with the wmode you can control the stacking order further by using the z-index along with the positioning. If two elements on a page are set to the same positioning, like relative, then the z-index will determine their stacking order.
