images not uploading to specified folder
Thread begun 2/12/2010 8:00 am by robert329616 | Last modified 2/16/2010 2:26 pm by Jason Byrnes | 6642 views | 9 replies |
robert329616
Hello,
I have been wrestling with this most of the night till now with the deadline in a few hours.
I followed the tutorials but have had no luck with the file actually uploading to the specified folder. I had errors with CS4 (added <?php?> at the end), so I switched to CS3 and received no errors. I then followed the dfp_da_insert_update_ht-1.pdf which added the image file name to the data base (which I needed) but still did not upload the file.
I tried on my MAMP server and GoDaddy with the same results. The code was added in the user_reg form that SecurityAssist created (per the pdf instructions).
Here is the code up to the form:
<?php require_once('Connections/dpConnect.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect="duplicate.php";
$loginUsername = $_POST['UserEmail'];
$LoginRS__query = "SELECT UserEmail FROM users WHERE UserEmail='" . $loginUsername . "'";
mysql_select_db($database_dpConnect, $dpConnect);
$LoginRS=mysql_query($LoginRS__query, $dpConnect) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL = sprintf("INSERT INTO users (UserFirstName, UserLastName, UserPhone, UserEmail, UserPassword, PetName, PetImage, ContestTerms) VALUES (%s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['UserFirstName'], "text"), GetSQLValueString($_POST['UserLastName'], "text"), GetSQLValueString($_POST['UserPhone'], "text"), GetSQLValueString($_POST['UserEmail'], "text"), GetSQLValueString($_POST['UserPassword'], "text"), GetSQLValueString($_POST['PetName'], "text"), GetSQLValueString($_POST['PetImage'], "text"), GetSQLValueString($_POST['ContestTerms'], "int"));
$Result1 = mysql_query($insertSQL, $dpConnect) or die(mysql_error());
$insertGoTo = "users_LogIn.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../images/petImages/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "4",
'ResizeWidth' => "200",
'ResizeHeight' => "150",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "PetImage", "0", "", "JPG:80", $WA_UploadResult1_Params);
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $dpConnect;
$WA_table = "users";
$WA_sessionName = "users_UserID";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "UserID";
$WA_fieldNamesStr = "PetImage";
$WA_fieldValuesStr = "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
$WA_columnTypesStr = "',none,''";
$WA_connectionDB = $database_dpConnect;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
Help would be greatly appreciated.
Thanks,
Rob
robert329616
Just in case here is the full page code -- thanks again.
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$MM_qsChar = "?";
exit;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>Registration</title>
<link href="WA_SecurityAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_SecurityAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="RegistrationContainer" class="WAATK">
<form action="<?php echo $editFormAction; ?>" method="post" name="WAATKRegistrationForm" id="WAATKRegistrationForm">
<h1>Registration</h1>
<table class="WAATKDataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th>First Name:</th>
<td><input type="text" class="WAATKTextField" name="UserFirstName" id="UserFirstName" value="" size="32" /></td>
</tr>
<tr>
<th>Last Name:</th>
<td><input type="text" class="WAATKTextField" name="UserLastName" id="UserLastName" value="" size="32" /></td>
</tr>
<tr>
<th>Phone Number:</th>
<td><input type="text" class="WAATKTextField" name="UserPhone" id="UserPhone" value="" size="32" /></td>
</tr>
<tr>
<th>Email Address:</th>
<td><input type="text" class="WAATKTextField" name="UserEmail" id="UserEmail" value="" size="32" /></td>
</tr>
<tr>
<th>Password:</th>
<td><input type="password" class="WAATKTextField" name="UserPassword" id="UserPassword" value="" ></td>
</tr>
<tr>
<th>Pet Name:</th>
<td><input type="text" class="WAATKTextField" name="PetName" id="PetName" value="" size="32" /></td>
</tr>
<tr>
<th>Pet Image:</th>
<td><input name="PetImage" type="file" id="PetImage"></td>
</tr>
<tr>
<th>Contest Terms:</th>
<td><input type="checkbox" name="ContestTerms" id="ContestTerms" value="1" /></td>
</tr>
</table>
<div class="WAATKButtonRow">
<input type="image" hspace="0" vspace="0" border="0" name="Register" id="Register" value="Register" alt="Register" src="WA_SecurityAssist/images/Pacifica/Refined_register.gif" />
<input type="hidden" name="MM_insert" value="WAATKRegistrationForm">
</div>
</form>
</div>
</body>
</html>
robert329616
I have been trying to work through the issue. When I copied the WA_DFP_AllUploadsDebug to the form page (started from scratch following tutorial with nothing else) I received the following:
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_2:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Still the same issue.
Thanks,
Rob
for a file to upload, the forms encoding type must be set to multipart/form-data.
change the form tag:
<form  action="<?php echo $editFormAction?>" method="post" name="WAATKRegistrationForm" id="WAATKRegistrationForm">
<form  action="<?php echo $editFormAction?>" method="post" name="WAATKRegistrationForm" enctype="multipart/form-data" id="WAATKRegistrationForm">
robert329616
Jason,
Thanks, I tried the change to the form. Where before I was getting the image name posted to the data base, now I am getting the following error after I submit:
Column 'PetImage' cannot be null
I just changed the table to default as null, I no longer get the error. Now it is not posting the file name(where it did before) and still does not upload the file to the specified folder.
Rob
you have the Dreamweaver insert record behavior on this page which you cannot use in conjunction with Digital File pro. You must remove the Dreamweaver insert record behavior from the page and use only the DataAssist insert record behavior.
robert329616
Jason,
I deleted the behavior and added the new one through DataAssist, still not working (probably me, too many hours not enough sleep), here is what I have:
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?><?php
$MM_qsChar = "?";
exit;
?><?php
if(isset($_POST["Register_x"])){
?><?php
$WA_fieldNamesStr = "UserEmail|UserPassword|UserFirstName|UserLastName|PetName|PetImage|ContestTerms|UserPhone";
$WA_fieldValuesStr = "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") ."" . "|" . "".((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") ."" . "|" . "".((isset($_POST["UserFirstName"]))?$_POST["UserFirstName"]:"") ."" . "|" . "".((isset($_POST["UserLastName"]))?$_POST["UserLastName"]:"") ."" . "|" . "".((isset($_POST["PetName"]))?$_POST["PetName"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".((isset($_POST["ContestTerms"]))?$_POST["ContestTerms"]:"") ."" . "|" . "".((isset($_POST["UserPhone"]))?$_POST["UserPhone"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,1,0|',none,''";
?><head>
<script src="WA_DigitalFilePro/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>DogPedic Sleep System Pawsitively Fabulous Photo Contest</title>
<meta name="description" content="">
<meta name="keywords" content="" />
<meta name="author" content="TriStar Products, Inc - www.buydogpedic.com">
<meta name="revisit-after" content="30 days">
<meta name="robots" content="all">
<link href="css/combined.css" rel="stylesheet" type="text/css" />
</head>
<body>
<?php include("includes/header.php"); ?>
<?php include("includes/mainNav.php"); ?>
<!-- editable content begins -->
<div id="contentWrapper" class="contentBckColor">
<div id="photoWrapper">
<div id="subcontent">
<div id="WAATKRegistrationForm_ProgressWrapper">
<form method="post" name="WAATKRegistrationForm" enctype="multipart/form-data" id="WAATKRegistrationForm">
<tr>
</tr>
<tr>
<th>Last Name:</th>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
<th>Password:</th>
</tr>
<tr>
<th>Pet Name:</th>
</tr>
<tr>
<th>Pet Image:</th>
</tr>
<tr>
</tr>
</table>
</div>
</form>
</div>
</div>
</div>
</div>
<?php include("includes/productBanner.php"); ?>
<div class="clear"></div>
</div>
<?php include("includes/footer.php"); ?>
Rob
that looks correct.
Add the following at line 1 to see if a php error is occurring:
error_reporting
(E_ALL);
also add the debug info back in.
robert329616
Jason,
Thanks. I received an error that the file I was tesing with was too large. It worked fine when I used a lower resolution file.
Should there be an error when I have DFP lower the res before upload?
With all the changes I have to go back and fix the double entries---much easier than this last issue.
Thanks again.
Rob
changing the image resolution can use quite a lot of system resources, try adding the following at line of your upload file:
<?php ini_set('memory_limit', '256M'); ?>
