enter multiple email for email lost password
Thread begun 2/11/2010 9:27 am by bryan107833 | Last modified 2/17/2010 12:23 pm by Jason Byrnes | 5661 views | 14 replies |
bryan107833
I have created a page within my admin area with a button to email credentials to a new user once an account is set up. I want to add a check box to send a copy of the email to a specified second email address(an admin email as we are having some issues). I have tried many different ways in which to add this second email address to the Security assist email password behavior source code but can not get it to send to a second email. It continues to send to the main email but that is it. Can you tell me how to update the code to include a second email. Thank you. Bryan
you would probably want the admin BCC'd. In the mail_PHP.php file, find the following:
if (strpos($mailBCC, "@")) {
    $mailHeader .= "Bcc: ".$mailBCC."\r\n";
and change it to:
$mailHeader .= "Bcc: youremail@host.com\r\n";
substitute "youremail@host.com" with a valid email address.
bryan107833
This does not use mail.php
I have universal email but when using the "Security assist email password behavior " it does not use mail.php and that is why I think I am having an issue. Can you explain how to change the below code. thank you.
<?php require_once('../Connections/acadia_mh.php');?>
<?php require_once("../WA_SecurityAssist/WA_SHA1Encryption.php"); ?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
require_once("../WA_SecurityAssist/WA_RandomPassword.php");
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php");
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("../access_denied.php");
if(isset($_POST["Send_x"])) {
$_SESSION["NewPW"] = "".WA_RandomPassword(8, true, true, true, "") ."";
// WA Application Builder Update
if (isset($_POST["Send_x"])) // Trigger
$WA_connection = $acadia_mh;
$WA_table = "visitors";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "UserEmail";
$WA_fieldNamesStr = "UserPassword";
$WA_fieldValuesStr = "".WA_SHA1Encryption($_SESSION['NewPW']) ."";
$WA_columnTypesStr = "',none,''";
$WA_comparisonStr = "=";
$WA_where_fieldValuesStr = "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."";
$WA_where_columnTypesStr = "',none,''";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_acadia_mh;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parameter){
$WA_MailObject = WA_SecurityAssist_Definition("mail.acadia-auctions.com ","587","webmaster@acadia-auctions.com","","","");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","",$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if(isset($_POST["Send_x"])){
//WA SecurityAssist Email object="Mail for Linux"
$WA_Auth_Parameter = array(
"connection" => $acadia_mh,
"database" => $database_acadia_mh,
"tableName" => "visitors",
"filterColumn" => "UserEmail",
"columnValue" => "".((isset($_POST["emailAddress"]))?$_POST["emailAddress"]:"") ."",
"columnType" => "text",
"usernameColumn" => "UserUserName",
"passwordColumn" => "UserPassword",
"selectColumns" => array("UserFirstName","UserLastName"),
"sessionVariables" => array("NewPW"),
"successRedirect" => "credentials_sent.php",
"failRedirect" => "error.php",
"keepQueryString" => TRUE,
"toAddress" => "UserEmail",
"toAddress" => "bryan@squeakywheeladventures.org",
"fromAddress" => "info@acadia-auctions.com",
"fromAddressDisplay" => "Acadia Auto Auctions",
"subject" => "Your Acadia Auto Auction Website Account Information",
"mailBody" => "Dear [UserFirstName] [UserLastName],\n<BR>\n<BR>\nXXXXXXX",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
the mail functions for the SecurityAssist Email Password server behavior are defined in the WA_SecurityAssist/Mail_PHP.php file.
look in the WA_SecurityAssist/Helper_PHP.php. the second line is:
<?php require_once( "Mail_PHP.php" ); ?>
please make the change to the WA_SecurityAssist/Mail_PHP.php file I suggested in my previous response.
bryan107833
Sorry, couple more things..The code you mentioned does not exactly match in my version (?) I guess of Security Assist. My code is:
$mailHeader .= preg_replace("/[\r\n]/", "", "Bcc: ".$mailBCC).$lineEnd;
Does this make a difference in what you sent?
Also, this is for trouble shooting as we are having a intermittent problem with users being send credentials and then them not working (I emailed with you last week about this and we did not find an answer). As you can see on the attached page, I have included a radio button to check if the administrator wants a copy emailed to them. Thus making it so that it is not always sent. Can we have this work instead of hard coding into the mail.php file? If not, does the above code I sent change your response at all. Thanks, Bryan
I think you are looking at the WA_UniversalEmail/Mail_PHP.php file.
Please make the change in the WA_SecurityAssist/Mail_PHP.php file.
bryan107833
Yes, I am looking at the WA_SecurityAssist/Mail_PHP.php file and that is where I copied the code from. Bryan
its really just a matter of adding
after the if statement.
bryan107833
So just ignore the "preg_replace"?
What about doing this on the page though so that I can bind the radio button? It does not seem as though I can bind this on the mail.php page? It is unfortunate that this does not work like universal email (even though I have universal email as well), since that would be much easier to work with. I tried adding another ""toAddressColumn" => "UserEmail"," but it just ignores it... Bryan
bryan107833
Is it not possible to add a second email address to "toAddressColumn" => "UserEmail"? Or to add a Bcc: field on the main page? Bryan
