Syntax Error: error occured in completeProcessing: eval error: SyntaxError: untermina
Thread began 2/11/2010 6:51 am by eaefaw380137 | Last modified 2/11/2010 5:43 pm by Eric Mittman | 1710 views | 1 replies |
eaefaw380137
I am using Surveyor 1.0.5, Dreamweaver CS3, Windows Vista Home Premium.
I get "error occured in completeProcessing: eval error: SyntaxError: unterminated string literal" when performing the following steps:
1.Insert>WebAssist>Surveyor>XML Site Map
2.Toggle: Create From Site
3.Next
4.Select WebAddress from pulldown menu. Remaining settings left at "Default"
5.Finish - Surveyor accesses all pages successfully and at the end of the processing I get the error indicated above. No XML file is created.
Please advise if you need additional information.
I have opened a ticket for you on this issue so that it can be looked into further. To check the status of the ticket or update it login and visit your support history.
