FF3 gap between WADAResultsNavigation and WADAResultsTable
Thread begun 2/11/2010 3:17 am by CraigR | Last modified 2/11/2010 6:38 am by John Langer | 3149 views | 3 replies |
CraigRBeta Tester
Not sure if I should post this in CSS or DataAssist forum.
i ran the da wizard to create a results page, and there is a gap between WADAResultsNavigation and WADAResultsTable when the page is formatted in FF3
Page dispays OK in IE8
John LangerBeta Tester
Hi Craig,
I've had this before. I found that there is some CSS generated on the results page that resides in the head of the document. One of these rules is:
.WADAResultsTable {
font-size: 11px;
clear: both;
padding-top: 5px;
padding-bottom: 10px;
I find that changing clear: both; to either left or right (depending on which side the sidebar is) fixes it for me.
Hope that helps.
CraigRBeta Tester
Sorted !
Cheers John. that's fixed it.
Another precious little nugget of info to file away!!
Regards
Craig
You're very welcome Craig, glad it worked out OK.
I scratched my head over that for ages before I sussed it out. Not really sure why WA put that code in the head. I assume it's so that it can be used on the front end as well as the backend of a site but I don't know. I generally cut it out and put it in my main CSS page. Then whenever I make a new results page I just put in a link the the main css page and delete the WA created code. Seems a lot of unnecessary work to me but at least I only then have one lot of code to fiddle with if I need to.
