Multiple cart buttons for a product using same quantity field
Thread begun 2/10/2010 11:27 pm by hcijun384863 | Last modified 4/06/2010 8:46 am by Jason Byrnes | 5964 views | 14 replies |
hcijun384863
I am trying to use three buttons such as "Buy Now", "Add to Cart", and "Wish List". Is it possible to implement such buttons for a product using same quantity field? For example, if a user enters 2 in the quantity field and clicks Wish List button, products will be saved in DB for future shopping, and if a user clicks Buy Now button, he/she sees a check out page, and if a user clicks Add to Cart button, he/she sees a normal display page.
The add to cart and wishlist buttons should be fairly easy to accomplish, but you will have difficulties with the quantity for the buy now button since the buy now button will need to be in a separate form.
you could make the quantity field of the buy now form a hidden element and update it using javascript that is applied to the onchange event of the quantity field.
the code would look like:
onChange="document.<formName>.<hiddenQuantityField>.value = document.<formName>.<QuantityField>.value">
replace <formName> with the name of the form, remember, you will have 2 of them, so you will need to get the right one for the regular quantity field and the hidden quantity field. also replace <hiddenQuantityField> and <QuantityField> with the correct names for the form elements.
hcijun384863
How to pull out wish list?
Thanks for your information about how to implement three buttons.
I am not clear about how to pull out wish list after I implement three buttons.
Could you please explain this?
what do you mean by "pull out wish list", please clarify.
hcijun384863
I mean how to create a wish list page.
Can it be done easily using ecart?
for a wishlist, you need to use SecurityAssist to add user log in, and DataAssist to store the items into a wishlist table.
when the user logs in, a session variable is created with their ID. you will need to create a new wishlist table that is used to relate the wishlist products with the users that added them.
the structure is fairly simply:
wishlistID -Primary Key
wishlistProdID - foreign key relation to productID in products table
wishlistUserID - foregn key relation to UserID in users table.
when the wishlist button is pressed, the productID and UserID are stored in the wishlist table.
to display the wishlist, create a join query on the products and wishlist table:
SELECT products.*
FROM products
INNER JOIN wishlist
ON products.productID = wishlist.wishlistProdID
WHERE wishlist.wishlistUserID = $_SESSION['UserID']
you will need to substitute the column names in your database and the session variable name as well, this is just an example of how the query will work.
the wishlist is really just another product catalog page, the only difference is that the products are related to the user who added them to the wishlist.
hcijun384863
Can't redirect to previous page
I have implemented wish list button in product detail page and it is working as expected.
For the users who has logged in, I can redirect to wish list page.
For the users who has not logged in, I am asking to log in and trying to redirect to product detail page again for wish list but it is not working. It always redirects to Profile.php page.
Could you please help me how to resolve this issue?
Partial of login.php page is as follows:
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $cwconn,
"database" => $database_cwconn,
"tableName" => "dim_customer",
"columns" => explode($WA_Auth_Separator,"Email".$WA_Auth_Separator."Password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"Customer_Code"),
"sessionNames" => explode($WA_Auth_Separator,"Customer_Code"),
"successRedirect" => "Profile.php",
"failRedirect" => "Emailpwd.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
the login success redirect is set by this code:
if you want to go to the detail page after login, change that to the detail page name.
hcijun384863
My questions is similar to return to previous url after login.
I changed login link from product detail page to the following:
<a href="login.php?accesscheck=<?php echo (urlencode($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):"")));?>">Login</a>
as you recommended from Pickle's post.
And I changed the form tage login.php page to the following:
<form action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>" method="post" id="WAATKLogInForm">
as you recommended from Piclke's post.
But I got the page not found error.
The url is as follows:
login.php?accesscheck=%2F%7Eclothw5%2FDetail%2FDress_Jumpsuit%2F12572.php%3F
Could you please help me?
looks like you login page is a folder down from the detail page:
login.php
try changing the login link to:
<a href="/~clothw5/login.php?accesscheck=<?php echo (urlencode($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):"")));?>">Login</a>
