Error when creating a menu
Hi after i have gone through setting up a new menu after i click finish i get the attached error message. Thanks Alistair
You may be experiencing a problem with the cache file, please follow the instructions here to delete this file:
If this does not work for you then there may be a corruption of your configuration folder. Here is a link to a post with the steps to take to resolve this issue:
showpost.php?p=12293&postcount=2
Please try these things and if you still have this problem let us know.
Deleting the dat file works, although i have to do it each time so i will unload all my extensions and then delete it thanks
