Trouble with finalising transactions
Thread begun 2/10/2010 2:33 am by smayer383553 | Last modified 2/11/2010 10:22 am by Jimmy Wu | 2195 views | 3 replies |
smayer383553
I have been attempting to use eCart4 and I am having problems concerning completing credit card transactions. I get the error message:
Fatal error: Call to undefined function curl_init() in C:\websites\gymbag\WA_eCart\Adv_CO_Scripts\PP_PayProUK_PHP.php
when I have chosen to finalise an order from the order summary page. Could you give me any advice on how to make the credit card payments work. I am using the paypal pro uk gateway and I have entered the info from the API into the checkout wizard. I have just followed the steps in the checkout wizard and the result is as above. As far as I'm aware curl_init() is a standard PHP function as it is explained on php.net.
If anyone could give me an idea of what went wrong that would be great
Thanks.
Jimmy Wu
Curl support is not enabled on your server. You should contact your server provider or server administrator to get this installed/enabled.
26167-fatal-error-call-undefined-function-curl_init.html
smayer383553
Thanks a lot that seems to have solved it
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
