DFP 1- delete file from specific folder not working
Thread began 2/09/2010 3:48 pm by webmaster286369 | Last modified 2/18/2010 3:13 pm by webmaster286369 | 2112 views | 2 replies |
webmaster286369
Hi-
I'm trying to delete a file using the delete file server behavior. It works fine as long as the folder isn't specific. However when I add the path for a different subfolder, it doesn't work.
(However the Insert and Update versions do, using the same method). Here is the code:
<?php //$folder comes in from the delete button links on Detail and Results pages
$folder= ((isset($_GET["foldername"]))?$_GET["foldername"]:"");
<?php //$_POST['file'] is posted with a hidden field down in the form, with the value coming from a recordset.
$WA_DeleteFileResult1 = false;
if(isset($_POST["Delete_x"])){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("../FILES/".$folder, "".((isset($_POST["file"]))?$_POST["file"]:"") ."");
it works if I don't include ".$folder" in the path, but i need that functionality. Any help?
Thanks, Justin
most likely the foldername query string variable isn't included as part of the forms action.
Set the action to:
 action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>"
this will cause the from to include any query string variables when posting.
webmaster286369
Thanks, that seems to work
