Light box not showing
Thread began 12/06/2010 9:54 am by balexander389215 | Last modified 12/08/2010 2:44 pm by balexander389215 | 2130 views | 5 replies
balexander389215
Can the gallery itself not be re-sized to fit a 760 wrapper? You are correct that trying to change the outterwrapper size leads to a whole set of new problems. I tried resizing the images as per another post, going to admin_gallery/common/properties.php and changing the 1024 array size to a 680x420 size and then changing the watermark to force a re-size but this had no effect. The images did not re-size. I must be misunderstanding the process. Considering your sitebuilder uses a 760 outterwrapper size it would make sense that the gallery could fit in this framework.
