Security Assist - custom redirect?
Thread began 12/14/2010 12:31 pm by omar419219 | Last modified 12/15/2010 9:03 am by Jason Byrnes | 1553 views | 3 replies |
omar419219
I have a database of five users.
i.e.
username: alpha
username: beta
username: gamma
they each have their own dedicated "dashboard: page within the same directory as the rest of the Secuirty Assist created PHP files
ie.
alpha.php
beta.php
gamma.php
I have also created a field within the database called "userpage" so each record has a corresponding value
i.e.e
record 1:
username: alpha
userpage: alpha.php
What I need is to customize the log in page so upon successful log in, the user gets redirected to their corresponding "dashboard" page.
the line I think I need to edit is within Log in page line 14 (Im guessing)
"successRedirect" => "users_Profile.php",
IDEALLY the value/url should be a result of something like: username+."php"
or
if that is not possible, it could be the corresponding value of the field "userpage"
i.e.
"successRedirect" => CALL_TO_THE_DATABASE_FOR_VALUE_OF_USERPAGE
Does this make sense? Is this possible?
you will need to hand code the logic to accomplish this.
create a new blank page called something like redir.php and set the login redirect to go to the redir.php page:
"successRedirect" => "redir.php",
On the login page, you can double click the authenticate user serer behavior, go to the third page of the authenticate user behavior and set the user name column to be stored in a session variable, the new session variable will use the same name as the column, so if the column is "username" the session variable will be too.
then on the redir.php page, you can hand code a header redirect to use the username session:
if(isset($_SESSION['username']) && $_SESSION['username'] != "") {
header("Location: ".$_SESSION['username']."php");
omar419219
Try it and got it to work! One small error (But I think this way due to may initial explanation) I had to change your code from
TO
header("Location: ".$_SESSION['username']".php");
(put period inside the quotes so the URL string would generate correctly. i..e alphapage.php VS alphapagepphp)
Thanks!!!
ok, glad to hear it is working.
