DAW keeps freezing/crashing
Thread began 2/27/2010 8:01 am by robert254422 | Last modified 3/01/2010 11:39 pm by Dani Chankhour | 1927 views | 5 replies |
robert254422
Hello... My data-assist extension but also others like css sculptor and mainly every extension that involves multiple steps in setting up structurally freeze/crash at step 8 of 10 or 4 of 6 etc... And in the case of Data assist wizard setting things up, up through step 8, still takes a good amount of time even if it does not get near to the time needed to do this all manually...
When I get to step 8 of data assist wizard... mostly 8 other times 6 or 7... after changing anything like order or label... All the fields dissapear (add/delete/sort order / columns)... trying back results in the popup crashing even more and displaying a horizontal scrollbar... If after that u say okay ill fix 8 through 10 manually after generating the pages also no luck because after step 10 you get messages like can not generate empty documents...
I have done things like cleaning DW cache, reinstalling extensions, using localhost etc... but no luck... To me it really seems like when trying to apply data assist to larger more complex tables it just can't handle it... to many actions or something... I don't know... Any help would be great...
WKR
RV
Office Guy-172461
It sounds like you might have a corrupted configuration folder. Make sure you are using the latest versions of all of the extensions.
146/
This article might help avoid future problems:
Installing Extensions
316/
If you provide info about your OS and DW version, someone might be able to provide more specific help.
How much memory does your system have?
robert254422
Been there done that
TY for your reply...
(cache / configuration / reinstall / most recent.)
all the obvious has been tried... many times...
It occurs with: vista / windows 7... cs3 / cs4.... 4 gb memory...
WKR
RV
Dani Chankhour
Can you tell me what version of DataAssist you are using?
robert254422
Version DA
I have 2.0.6 installed...
WKR
RV
Dani Chankhour
I did a test on Windows 7 with CS4 and i could not reproduce this issue.
I don't think it is related to the table structures, but is it possible you can send me a dump of your database so i can run a quick test using your tables. You can clear all the tables and just send me the structure.
