broken link in UI
Thread begun 5/11/2009 3:18 pm by maureen353022 | Last modified 5/12/2009 9:01 am by maureen353022 | 2644 views | 2 replies |
maureen353022
broken link in UI
I'm using CSS Sculptor 1.1.5 on DW 9.0 Build 3481.
When I open CSS Sculptor, there are two broken links in the upper left corner. I'm assuming they're javascript. I have tried deleting the macfilecache.dat with no change.
Broken links also show up in Memento. I'm assuming the issue is the same...
Any and all help is appreciated.
This is a bug associated with the quicktime update on MAC interfering with the way DW displays (or stops displaying) some small .jpg images we use for the background.
We are fixing this issue by moving to .gif images for any updates or new releases, but you can ignore the issue in previous versions since it should not effect functionality.
maureen353022
Thanks. I'll squint and ignore it.
