Spry Autosuggest with Dynamic dropdown
Thread begun 2/07/2010 10:58 am by NYC_GUY | Last modified 2/09/2010 10:24 am by Jason Byrnes | 1816 views | 1 replies |
NYC_GUY
It seems WA does not have an autosuggest extension. Has anyone used Spry Autosuggest with Dynamic dropdown extension? Is there any simple instruction/tutorial for this?
Thanks in advance
No there is no tutorial for using Spry Auto Suggest with Dynamic Dropdowns.
The Auto Suggest component will really only be able to be applied to the main parent list, since the data for the child lists is populated dynamically based on the selection of the parent list.
The major hurdle to overcome will be creating the DataSet for the Auto Suggest wizard to use, you will need to manually create a page to loop through the database table for the parent list to create an XML data set.
