Checkout Failure (Sandbox Testing Using MAMP)
Thread begun 1/26/2010 1:22 pm by Dante48Chicago | Last modified 3/12/2010 6:38 pm by Dani Chankhour | 6342 views | 9 replies |
Dante48Chicago
I have researched a lot of the posts in the "checkout wizard" search for my answer before posting this. However, I saw bits and pieces of solutions but not a completely exact case scenario. So here is what i THINK my deal is in a nutshell: CHECKOUT FAILURE. From what I have read in the forums I believe (not sure) the issue is in the BINDINGS (which I vaguely understand or know how to operate).
Prognosis from PayPal:
I am not hitting the PayPal Sandox servers at all. Issue is on side of eCart / Dreamweaver.
PayPal recommednation:
Turn on "logging" to see what the error is in the Checkout Failure. I assumed what they meant by logging is the exercise of adding the "bindings" to pages: checkout_failure.php and pp_checkout_failure.php and then testing the VISA card test buyer VISA credit card again. I already did that and I get no data on the browser pages, no XML anything, no nothing in the areas where I inserted the "bindings" on to the pages (see bottom of post).
So that is what PayPal told me above and you can see I already attempted to troubleshoot this before writing this forum post.
Here are my settings and configurations
Computer: iBook G4 PPC Mac OS X (10.4.11)
Dreamweaver: Version 10.0 Build 4117 (CS4)
eCart: 4.5.2
PayPal: PayPal Payments Pro
Testing: Sandbox, Seller API credentials. Buyer Agreement executed. Using SANDBOX settings not Live API settings. (My PayPal account is active, approved and in good standing for PayPal Payments Pro Merchant Account)
MAMP Pro: Installed and running successfully locally. Successfully added the sample eCommerce Database (not sure how to use it yet but it shows up in my databases). However, I am not storing any data in the databases as i unchecked that option in the Checkout Wizard (no shipping data either).
Server Language: PHP
Browser (Preview): Safari 4.0.4
Ok so there are my settings above. Here is what I have already done to trouble shoot the issue myself:
Troubleshooting Activities Performed:
1. Cache: deleted DWCS4 cache file several times and restarted several times.
2. Created "Add to Payment Response Bindings" from Debugging eCart Transaction Failed Issues
Browser Results (Zero Results):
PayPay Express Checkout Button:
<div class="eC_Simple_Pacifica_Arial" >
<h2>Transaction Not Completed</h2>
<h3 class="eC_InfoHeader" >We're sorry</h3>
<div class="eC_InfoContainer" >
<p class="eC_OrderInfo">Your PayPal transaction could not be completed.
</p>
<p class="eC_OrderInfo">(Authorize Express Checkout below)</p>
<p class="eC_OrderInfo"></p>
<p class="eC_OrderInfo">&nbsp;</p>
<p class="eC_OrderInfo">(Process Express Checkout below)</p>
<p></p>
<p></p>
<p></p>
</div>
</div>
PayPal Direct Payment
<p class="eC_OrderInfo">Your transaction could not be completed.
</p>
<p> <p>
<p>
<p>
<p>
<p>
</div>
</div>
Basically I get to the Order Confirmation page and when I submit I get the above error. In the case of PayPal Express Checkout when I click that button I just get the same failure page notice.
If this is an issue of me not setting the BINDINGS can you please point me to how I can do this? Or help me resolve this issue. I did not see any tutorials on this or any PDF download files that address bindings, etc.
Thanks for reviewing this and for all of the excellent support you have given here on the forum.
Dante
UPDATED:
I performed a search for "checkout failure" and found this post: showthread.php?t=8358&highlight=checkout+failure
I followed the instructions and added the "Full Request" binding, previously I only added "Full Response" which was what I read in another post that was not accurate. Now I have a result from the "Full Request" but this information, even though it is test sandbox data, looks sensitive and I am not comfortable posting it in an open forum.
What should I do? Please advise, thanks.
Dante
Dani Chankhour
Are you using Test Credentials to test with or are you using the Live credentials.
If you are using the Test Credentials, then you will need to enable the sand box:
look for these two lines on your confirm page:
$PP_DirectPayment_required[0][$nextIndex] = "UseSandbox";
$PP_DirectPayment_required[1][$nextIndex] = "true";
and if you are not using the Test account, then change it to:
$PP_DirectPayment_required[1][$nextIndex] = "false";
I just want to mention that you can't use live credentials using sand box and you can't use test credentials when not testing in sand box.
Dante48Chicago
I am using TEST Sandbox Credentials
Hello Dani!
Thanks for your reply. In my outline I indicated I was using Sandbox Credentials (see below cut and paste for that excerpt in my original post):
"Testing: Sandbox, Seller API credentials. Buyer Agreement executed. Using SANDBOX settings not Live API settings. (My PayPal account is active, approved and in good standing for PayPal Payments Pro Merchant Account)"
I will look in the confirm page and see if those two lines of code are there.
Dante
Dante48Chicago
Confirm Page Uses Sandbox Settings
Dani,
The below code is directly cut and pasted from my confirm.php page:
The above code is in the actual confirm.php file I built using the Checkout Wizard.
However, the page the browser displays does not contain this code. Not sure if that matters or not?
Please advise what my next steps should be.
Thank You Dani,
Dante
Dani Chankhour
I have opened a support ticket to further assist you with this issue.
karl.allen344191
I bet you have, but you are using the "Sandbox API Credentials", as on my Payments Pro Account i have a login for Sandbox and a login for Live, both have different credentials and sigs.
Have you tested your credentials using a stand-alone script to check if its the credentials at fault and not ecart?
Dante48Chicago
API Credentials Are Correct
Hi Karl,
Thanks for your reply. The API credentials are correct. I absolutely know the difference between Live and Sandbox API Credentials. I am using Sandbox API Credentials not Live as I have an active PayPal Payments Pro Merchant account that is currently processing payments through another storefront using my Live API Credentials. I know the difference between the two logins: one for the Live PayPal and the other for the Sandbox.
I believe the issue in the endpoints according to the PayPal tech support. The URL is wrong and I believe that is part of the issue if not the entire issue.
Again, thanks for your reply. Hopefully I can get this resolved and I can complete my testing and take my online store live ASAP.
Dante
Miguel
i got a similiar problem but on a live site the order always sends me to the checkout failure page, i have a new post opened hope i get help soon. And i have try all things here on the forums with no luck
Dante48Chicago
Good Luck. I am seriously contemplating moving to Magento, an open source ecommerce platform and scrapping eCart for now until I can spend more time on figuring it out. It's a bit to complicated for my head at the moment.
Dani Chankhour
To debug this issue, please place this code in your failure page. This will give more information about the error you are getting and why it is sending you to the failure page.
if(!session_id()) session_start();
     echo
"Direct Pay: <br />";
     echo
"Full Request: ".isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a"."<br />"
     echo
"Full Response: ".isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a"."<br />"
     echo
"Express Authorize <br />";
     echo
"Full Request: ".isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a"."<br />";
     echo
"Full Response: ".isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a"."<br />";
     echo
"Express Process: <br />";
     echo
"Full Request: ".isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a"."<br />";
     echo
"Full Response: ".isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a"."<br />";
If you still having issues, please post back with the respond with the output you are getting on the failure page. Make sure to remove your credential information before posting.
